need to load the Ino modified in your autosteer board
reload the AOG value steer & the raise and lower (as you show)
physically add some relay to transform and isolated D2 D5 signal
connect the relay to switch of the tractor in parallèle
after start a field
make bondary, headland , AB line
activate the ABline , the headland, raise lower icone( need to be green) , auto section and accross the headland line
green or orange Arrow will be show action and autosteeer board send to D2D5 the action
@Kaupoi because I m really curious about this new feature of 5.5 , i cannot wait more and i test on simulator/board with the actual modified autosteer.ino
First Brian &co do very good improvement !
second on simulator with board it is working !! so so good!
Mine is not working. Testing by driving tractor on yard. Using your ino I downloaded couple months ago. Arrows goes up and down on screen as they should, but nothing happens in steer module. If I tab “invert relays” and send at hydraulic lift config window, relays pull and jd screen shows error. So relays does work and pinout is correct anyway.
What could cause this issue?
Did you modify the latest ino or using the older modified one?
SOLVED: Autosteering must be engaged for lift control to work.
Realised that autosteering must be turner on for lift control to work. Tested again with autosteering and it really works. So it was just a stupid user error. Sorry for bothering you with this and thank you for this awesome mod.
