Now I don’t know if this a success. But here it goes.
I made a controller for AgOpenGPS with a Raspberry Pi 3. Software is written on Python. Now why an earth someone would do that? It’s just something I had lying around. At least it can be done. There are no custom PCB but too many wires.
I have installed steering wheel motor and wheel angle sensor for 3 tractors and 1 combine.
First I wanted to make hydraulic steering. Hydraulics are just not within my comfort zone. And I thought steering wheel motor is more safe if (when) something goes wrong. And cheaper.
There are no section control implemented.
Components
- Raspberry Pi 3
- Wheel angle sensor RTY120LVNAA. ±60 degrees
- Adafruit ADS1115 4-Channel ADC
- Adafruit 4-channel I2C-safe Bi-directional Logic Level Converter - BSS138
- BNO085 Absolute Orientation Sensor. Adafruit version is really hard to find anywhere. I used Chinese Aliexpress version. I have doubts on whether it has the same firmware.
- Cytron MD13S PWM Motor controller
- a micro switch
- 4 LED:s (and resistors).
- 12 V cordless drill
- Motor wheel is a wire brush wheel, wires cut off, double sided mounting tape for a little cushion and hockey stick tape for a little grip. Self vulcanizing rubber tape has got a better grip, but it doesn’t last very long.
Control box
Wheel angle sensor installation
Steering wheel motor installation
There are some steering wheel motor designs. Two old 12 V drills and two new (cheapest I could find).
This is the latest desing. It is the most easiest to make, there is only one weld for the handle mount.
This is the first design. It’s not bad. It’s just really time consuming to make.
And one for combine.
This design is too weak.
Cabin
Computer is a used Surface Pro 4. It is actually quite good for this purpose.
