Hi!
I am using a switch combined with my hydraulic hight to activate/deactivate auto steer. I want to include the current limit function to switch of the auto steer in case of trying to move steering wheel manually against the motor. It works but if the current is back in range the auto steer is immediately active again. This is not good in some cases. Wouldn’t it be better to reactivate it manually by switching it off/on or push the auto steer button in the software in this case?
If you use a hardware button instead of the switch it works but in combination with the hydraulic hight I have to use the switch function.
Or is there a way I don’t know?
Best regards
Christoph
