Short guide how to fit Adafruit BNO085 to KaupoiMOD PCB v3.
Thank you. Was hoping Iâd find something like this but wasnât able to
A topic all about it. Please feel free to post your adventure and some pics to add to it.
v 5.1.6 downloaded May 28. I have successfully run AoG previously on my desktop. Today this Unhandled Exception pops up when I click âopenâ field. I figured out that somehow Field.txt was missing (from a field that I had created & used on the sprayer) now after syncing to my desktop. I just made a copy of Elevation.txt (looks identical to Field.txt on other fields) and renamed it to Field.txt and now itâs happy again. It might be a good idea to capture the exception and tell the user which field/file is the culprit.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.Collections.Generic.List`1.get_Item(Int32 index)
at AgOpenGPS.FormFilePicker.FormFilePicker_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4360.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
AgOpenGPS
Assembly Version: 5.1.6.0
Win32 Version: 5.1.6
CodeBase: file:///C:/Users/Matt/Seafile/AoG-5.1.6-master/AgOpenGPS-master/AgOpenGPS_v5/AgOpenGPS.exe
Win32 Version: 4.8.4341.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 4.8.4084.0 built by: NET48REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
OpenTK.GLControl
Assembly Version: 1.2.0.0
Win32 Version: 1.2.2336.6514-pre
CodeBase: file:///C:/Users/Matt/Seafile/AoG-5.1.6-master/AgOpenGPS-master/AgOpenGPS_v5/OpenTK.GLControl.DLL
OpenTK
CodeBase: file:///C:/Users/Matt/Seafile/AoG-5.1.6-master/AgOpenGPS-master/AgOpenGPS_v5/OpenTK.DLL
Control.Draggable
Assembly Version: 1.0.7235.37687
Win32 Version: 1.0.7235.37687
CodeBase: file:///C:/Users/Matt/Seafile/AoG-5.1.6-master/AgOpenGPS-master/AgOpenGPS_v5/Control.Draggable.DLL
RepeatButtonControl
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/Matt/Seafile/AoG-5.1.6-master/AgOpenGPS-master/AgOpenGPS_v5/RepeatButtonControl.DLL
Microsoft.GeneratedCode
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Can I request that when cycling through AB lines, please update the current AB line text at the top of the AoGâs window immediately. Now it takes about 2-3 seconds to display the next AB.
Another request, something to make it easier to expand the Auto Steer Configuration window to see the manual drive & steer angle recorder. I find it difficult to grab the edge of the window on my Switch Alpha 12. Maybe tapping/clicking on the âSet Act Errâ bar is possible.
Lastly, when I save a vehicle on my desktop (4k display) with AoGâs window positioned low-right, then after loading that vehicle on my tablet, it loads AoGâs position off screen. Is it possible to limit AoGâs position by checking current system desktop res?
Probably the easy answer to that one is just donât remember the position and start out in default position
Yes, that occurred to me too. Is there an option already in AoG that Iâve missed?
Brian, on the latest Urepom version, I record the FormSteer position, FormSteerGraph position and size, FormEditAB position and oglZoom position and size.
I also display the name of the AB line in opengl with click on it to switch the line (with speed conditions = 0 or autosteer off), this itâs because I hide all the buttons with a click on the basemap tu have more fullscreen.
Also Maybe it would be good for your version.
There is literally no end to all the things you can save and improve. Very good ideas yes, but as you see from m_elias post, saving those is good for some, bad for others.
