Wondering if anyone can post some pics of their mounting ideas on telescopic and tilt steering. I have a JD 6115D with a fairly short telescopic and tilt console. Next to no space and very tight. Left hand reverser plastic box is the only part that travels in all directions with the steering wheel. Curious what others have done.
I am using @PotatoFarmer’s gear and quick tach setup
Here is my console, rubber boot on tilt. image|690x459
on jd6000 6010 6020 6030 or M i create this bracket on steering that after i can fix the mecanism it looks like your steering …
or as alternative you can get only autosteer on lower position and you disengaged by pulling the steering wheel… ( i do that for claas combine steering work only in lower position, not easy to see on the video
Yeh I wanted to try get it in all positions. Think i got it, ill post pics tomorrow.
The green part telecopes in and out, the purple stays fixed, plus the whole unit tilts. Added that collar hidden in left hand reverser box, seems like it works so far, but havent powered the box yet.
Got some pics this morning, just need to take it off and touch up some welds and grind down the corners, but seems to work well. Full use of both the tilt and telescope still too!
Hi
i don’t know witch one wood you see more…
in first time i must thanks you for the clutch of motor it’s wonderful.
For the IH 845 i have print support to fix it to steering column
Sorry my fingers are so fat…
I said the gears of steering wheel are made with PETG and motor gears are print with PLU (modification of motor axe for diameter)
I use motors in 12v from KATODO italy (E 192.12.13) i will test them in few days after mounting wheel angle sensor on witch rover but i must work some fields before…
