Hi
i take a picture of my steering motor on JD 6600 this mount is made of metal but steering wheel could move up and down without motor. Nevertheless i don’ t move it.
I also try this week end to use the steering motor but i forgot that i didn’t install W A S on the rover…
i suppose if you don’t have WAS it’s not possible to have steering motor?
I also have a mistake with CMPS 14 + ino not recognise perhaps usb cable.we will see that later.
Have a good day Michel
i fix the support through the board and under the column witch not block bending of column, i can pull up the steering wheel but without motor also i’m not a tall person so i don’t have to pull it…
i’m sorry i don’t take any picture when the board was open.
I think it was also possible to print (3d) a bridle as i made for 845 IH around square column witch not block pulling up steering wheel with motor.
i hope it’s clear for you the Shakespear language is not the better for me…
I only use PP for the moment and i’m so happy.
sorry i try to show you some videos but i can’t maybe later…
If i can use my project now i mutch thanks all of you for your grate job between many years.
i can’t do it without your works it’s wonderful.
Don’t worry i need some help again with CMPS 14 and arduino. we will see that a other time.
Minimum to move for this motor in settings are 1
Stronger then phidget,faster,chiper, more roboost.No reduction, no need for mechanical disengage.It goes easy allways connected.
On my small 49hp tractor i menaged with this motor to go 35km/h and holds in 2-3 cm
On fast direction change it consumes obaut 15Amps , on slow movement 3A.
Hi James
witch picture would you say?
if it is for ih 845 that’s only 3D print; if it is for JD 6600 the clutch is 3D print the support of the clutch is metalic . clutch is made with bricbric model.
Aha- yes the JD6600. How did you mount the motor with no bolts at the top, and having potato farmer gear so close to the clutch ? I have a clearance issue with a short drive gear and motor bolts with a phidgets motor.
The motor is mount with 3 bolts on the top with a little modification of clutch with cura because motor is katodo one ;axel diameter is 8mm like this picture.
Hi Daner!
I am thinking of a similar solution.Is this an Opel Corsa C EPS motor?
Could you send me a few photos of how did you connect the motor with the wheel.With gears,belt or with friction drive?
Thanks,
Laszlo
