Friend reckoned this system wasn’t much cop on his combine, so he never uses it.
I wonder if I can improve it, somehow…
Copied from elsewhere on here:
1,2 - Motor +
3,4 - Motor -
5 - unused
6 - encoder 5v
7 - encoder ground
8 - encoder channel A, open collector
9 - encoder channel B, open collector
I just wired up 1 and 3 for a quick test.
Sounds like you are training a new ag electronics technician in the video!
He should be training me, I think !
So it’s a DC motor instead of a stepping motor?
I also have an EZ-STEER motor, can you send a detailed pin diagram? I can’t tell which is the first leg on the DB9 interface.
It’s not a stepper motor, no. Just a regular DC motor.
The pins are numbered if you look closely at the plug. Standard db9 numbering. Here’s a serial port, but the numbers will the same. This is a male plug:
Per my guide above, I used pins 1 and 3 (top left, and 2 along)
The EZ steer has a good second hand value on eBay and the like. Lots of people heavily invested into the Trimble Ecosystem.
Would easily sell it and get a Phidgets, brackets etc. and have plenty to spare.
Of course as a challenge, well, can’t put a value on that!
