but i think the actual choice is really better
because for each combination autosteer ajustement is different
Pulled accessory or 3p linkage/ tillage or mowing / can really change the autosteer setting and if you modify for your actual job you modify for other and you always readapt your ajustement
Even if it is boring when you create a new tools you can use an already one and modify it
Same here, have one generic good tune for the tractor to start with, and then do a save as with the tractor + implement name after tweaking for each implement.
Just found this, China Mfg. hears our every word.
The preassembled 485 cards now come with Ethernet.
What I miss since V4.3.10, well sized icons for touch buttons. The actual size works for the office PC, but in the tractor displayed on a tablet, you canât see any details, too small.
What kind of tablet? is it high resolution? Can you take a screen shot of how it looks? Perhaps increase your scaling? Usually the complaint is too big icons
I only discovered this thread today, and I will chime in that since we switched to Wifi + UDP, we donât want to go back to USB. We use the Mobile Hotspot feature in Windows to create the âhubâ, and connect to the Internet using our smart phones hotspot, this way the tablet is portable from tractor to combine, and whoever is driving uses his phone for Internet for NTRIP. We rewrote all Wifi code to make the WIfi autoreconnect if the network goes down temporarily. We can even take the tablet outside if we need to work on some of the modules like GPS or machine control. No cables, no mess.
Hello (this is a Google translation ). I donât know anything about UDP, but I wanted to get started. my question is simple. Can we have two modules in UDP (gps and autoguiding) but stay on USB for the IMU? Because I made myself small boxes for the BNO085 and NANO, very easy to place.
Well then, if the tractor and machine settings are separate, let the person who has different tractor settings for the machine write down the tractor settings, eg âJohn Deere cultivatorâ and load them and then load the cultivator implement. Two more clicks. But for a person who has the same settings, it is a tragic solution. She has to keep a sheet of paper in the tractor and if she adjusts something in the Autosteer settings she has to change them everywhere ⌠In commercial systems, for a lot of money there are one setting for tractor and on the welcome screen you load the machine, select the field, enter the work and you can go. Or maybe we can add function to keep two option of load settings?
I agree with that, then it would be possible to have 2 or more tractor settings (Example: Fendt below 10 kmh and a Fendt over 10 kmh)
After that select the implement with its settings.
Or other way around, if you find the tractor setting used right now with implement should be the other, then just change tractor, and AOG says: steer settings sent
Hello, I am currently converting to udp. There is no connection to cmps14 in agopen GPS, after send and save there is a connection. However, after restarting the arduino, there is no connection again. What can I do there?
So there are two ways about this, one is to make your computers address match the Arduinos sub net, or to make the Arduino match the computers sub net.
So what we are looking for is that both the computer and the Arduino and the Computer both belong to 192.168.1.xxx, or whatever you feel like typing in the first three boxes as long as its the same as your computer.
Brian made a wonderful video outlining how this works.
coffeetrac already has working esp32 steer code, using it I want to remote mount cytron + esp32 right on the motor holder to steer by UDP wifi. This would also have the clear benefit of having cytron to motor wires being super short.
If it works wellâŚ
Really the only odd duck out in the modular UDP easy connection party is the WAS.
