What did you do.
Try connecting up the was and try
Did you select Cytron in AOG and send settings to teensy?
First thing mh 12/24 converter didnt work ir mounted after PCB, mounted ir before pcb.
Dont have any potentiometer near me, so dont oportunity how to try was.
Aog set to cytron, but in pwm mode doesnt turn on motor.
Show picture of your screen where AOG is in “pwm” mode.
What colour is your 2 steer icons at bottom right?
Diseconnect motor and measure again
Wait so you had the 12 to 24 volt converter connected between the motor and the cytron output?
That wouldn’t have done good things for anything I cannot imagine.
hello everyone
is there a wiring diagram for the v4.5 board, if so where can i find it?
Use easyeda.com with these files
(Boards/TeensyModules/AIO Standard v4/PCB Build/AIO v4.5 Std/EasyEDA files at main · AgOpenGPS-Official/Boards · GitHub)
I have a v4.5 aio board to be installed in a t7.270 new Holland. It isn’t auto steer ready so will be putting a valve on it. Can I use can bus with this board to be able to use the original auto steer button on the joystick?
Yes you can use the engage button if you use the CANBUSEnable aio firmware ive used it and it works well
Connect to pins c and d on the black plug on the rear pillar with pins 16 and 17 on the aio board
Ok, the diagnostic plug on the pilar?
Yes the black one.
You could put a plug into the front but that would look crap so i pulled the trim off and got to the wires on the rear. They are green and yellow twisted pair. I just joined into them
That’s grand I will give it a go. Thanks
Where can I find this firmware, is it on the configomatic?
Its the canbus firmware in the main boards repo
What settings do I need to change on the tractors h menu?
Are you steering via canbus?
In h menu h1 steering needs setting to yes.
In h3 you will need to preform a WAS and SPOOL calibration to unlock the valve. This is not an easy procedure and often takes a few attempts
Not steering via can bus. I just want to use the button.
You wont need to go into the h menu then.
Just connect to the black plug on the pillar are wire it to pins 16 and 17 on ampseal
