Virtual Turn sensor for electric motor
Code dedicated to the electric motor and its disengagement in the event of an error accumulating on the setpoint.
Define a new virtual steering wheel rotation sensor that can be adjusted in the AgOpenGPS parameters.
During self-steering, the WAS evaluates the error in the WAS setpoint (wheel angle sensor): If the error is maintained or reduced, this can be considered normal. But if the error increases more and more, it is an abnormal situation: such as the steering wheel being taken over manually or the steering sensor having a problem.
This code checks the evolution of the error and accumulates an index according to the abnormal situation.
The result is that it stops the autosteer if the value of the steering wheel rotation sensor is greater than the index.
Depending on the quality of the AgopenGPS response and the hardware, we can set the value of the turn sensor between 30 and 60.
Because it is based of number of error the autosteer will be disengaged with 0.6-1.2s and it will be link according your electric motor and reactivity setting
In case you are not satisfied you can set off turn sensor to cancel the function
if you can test it can you report your setting ? or report that it is not good
Due to my experiance I think the most dificult is on line with very few modification … that probbably we can add 1-0.5% error comparaison
File available
for Switch mode and autosteer stop (code from @m_elias ) permit to use Switch in this case
Note the compiled HEX is NOT up to date on my repo
Small update and first feed back
Probably not the best but give a level more of safety in case of
need to adjut steering more aggresif on the line than soft to try to control the steering
In 24V the time to disconnect can be burn the fuse if you use voltage transformer
so less agressivity with max load for that can be a solution
Files for version AOG 5-to 5.6 are located here
Update
add 1% of 1% to kill very low modification
Tip: that it will work with an efficiant starting turn that make a significant error growing
release updated
Release update coeficiant · Entropiemaximun/AOG-electric-motor-release-by-virtual-Turn-sensor · GitHub
Hello everyone.
Does the AIO board 4.5 need to be modified to use this code?
Yes
you can find the lastcode in the last release
don’t hesitate to feed back your result
Normally soon i will update with some improvement with collaboration of @Daniel
This firmware update saved me a lot of work. No need to fix my faulty turn sensor now.
JD 6920s, hydraulic steering (Hydraforce), KaupoiMOD (nano)
Thanks!
Thanks I hope this can be consider on next release
Also i update last one that we improved with @Daniel
Danie mode can be activate by Danfoss function
  • add delay at start autosteer 1.5s
  • Cancel function at low speed <1km/h
  • Cancel for small angle daniel : 0.5° bric bric : 1.5°
cancel value based
  • Daniel: proportionality sum with value of angle
  • BricBric: count of error
Has this been added to the main release of AoG by chance? Does it work with hydraulic steering or just electric motors?
it can works with hydraulic steering if you can steer manually during autosteer
for me not added to new release but i propose
Made this video earlier of it in use with a Baraki hydraulic valve.
Looks like it works well with hydraulics! Hopefully they add it to the main branch soon, that would be handy for a lot of people!
It means in hydraulic you can get around 0.3-0.4s time to disengage
That in electric mode 0.5-0.6s that i can get
and clearly related to the reactivity of the system
For now have to load the dedicated firmware from GitHub. See the links from @bricbric above.
Next firmware generation will have a webpage so it will be easier to add new features.
For now it’s not tempting to add new settings in the PGNs as it would force everyone to load a new firmware.
Keen to use this on a aio v4 board hydraulic valve. Do I just add code to teensy?
Hello
yes you can use it on teensy
What valve you using it on
