So I have problem with panasonic FZ-G1. It has windows 10. Internet works fine from sim card when my usb to lan adapter is not connected, but when I plug it to tablet internet goes of. Ethernet goes only to pcb. I have set interface metric value to 15(is lowest number) in 4G connection (ipv4). With wifi internet works even when usb to lan adapter is connected.
Yesterday i had same and fixed it by adding fix 1 in registry
Thaks. I did metod 2 and it works now!
Hello, I had the same issue with FZ-G1 under Windows 11, I solved it using the free version of SPEEDIFY (limited to 2Gb per month, should be OK if used only for RTK i.e. no windows update, no youtube…)
