Has anyone used the output speed pulse to supply a speed signal to either a Rauch Quantron M speader controller or a RDS Artemis drill controller?
The drill controller has a RDS satspeed 2 gps reciever on it at the moment and Im wondering if I can just connect the speed pulse output to the input on the controller. Satspeed specs are:
The Quantron M has the 7 pin plug and takes either radar, gps or wheel magnets. Could speed pulse output from AOG just be feed into Pin 1 below?
Any input is appreciated
Pat
August 24, 2023, 1:15am
2
I think it’s like the ISO connector:
Hi
i want to build this connector in my old tractor to connect equipements like an APV.
[iso11786]
Official ISO11786 Data signals
5.1 Signal characteristics
The signal characteristics for true and theoretical ground speed, PTO rotational speed and linkage are so specified as to be compatible with CMOS logic as defined in JEDEC1), powered from the tractor battery with a minimum voltage of 10 V.
5.2 True ground speed and theoretical ground speed
5.2.1 The signal shall be a square wave …
Yes, if you have a V4 board, you can plug the SPEED+ pin, it wont hurt the controller.
Maybe it will need a 2k pullup to work.
Follow this tread:
Speed pulse output at the AIO board should be according to the ISO standard in order to avoid issues when connecting different types of implements, or have to solder pullups or pulldown resistors.
The ISO standard is higher than 6,3V and lower than 1,5V. Square pulse
Thanks for that, I will give it a go
