Arduino UDP doesnt read bno when first starting up
Hello, building my third autosteer and i run into a problem. When i first open aog the bno data shows 0 when i click the reset button on arduino it shows the roll value. I have tried different arduino, bno, resurse it two times. Never had this problem before. Im using V2 PCB with ethernet shield.
Hello, I had this
same problem. With a delay of 2000 before void setup it works
Thanks will try tommorow.
Thanks it works
