It’s panda board not autosteer + panda.
It can be that too
Yes, but where can I download a PCB like Davids single design or other (UDP only - Where is AOG heading - #29 by BrianTee_Admin)
Not ready yet
Good News Everyone!
Turned down the roll to 1 or 0, Big success PANDA now works. Thanks @Vili ![]()
Way less gittery, I am running with V2 imu too does not seem to matter a bit, at the moment.
So fully compatible with older boards!!
Lots of 01010101010101cm
Very good!!!
I find one teensy 4.0 in stock hire, both 4.1/4.0 will work for panda but are PCBs slots same/compatible ? (is 4.0 good or it will be better to wait for 4.1?)
4.0 doesn’t have ethernet so will that be problem for UDP only future?
What would be simplest way of making GPS+IMU+TEENSY USB upgrade for v2 ? Or make new teensy PCB?
I hate to say this, at the current date, but if you already have V2 just solder a f9p and Bno to the teensy with wire, use the teensy dev ethernet kit for port, and 3D print a small box for it.
Or if your box is huge just stick them in with good double sided tape.
Im still trying to get GGA to teensy by UDP, so that the gps can be anywhere.
3 way ethernet spliter connected to that, connected to USB hub, back to tablet. Chain getting quite long.
So 4.0/4.1 can be interchangeable on PCBs good.
Which exacly for 4.0 I see just for 4.1.
Big enough to 3d print and put it inside AOG box. Soldering wires then it is.
Just get the 4.1, the port kit for it plugs in.
The teensy is very powerful, I doubt AgOpen will max it out any time soon.
Its better to go 4.1 but its out of stock, question is it better to go 4.0 right now or wait for q1 q2 of 2023 for 4.1?
One of better games in all time ![]()
I found some at ABRA.
International:
We only ship in Canada and the USA.
But there is only one shop that keeps teensy in stock in my country, I did find them on Digikey but that’s 30$ + 80$ shipping and 32% import tax on price+shipping and some adicional custom handling fee of 30$. So 30$ board finish as 175$ order(all such sites have expensive shipping). Importing is really last option when you cant find locally that 4.0 is 40$ locally.
Where do you live?
Serbia
This is a german shop:
Teensy 4.1, ohne Header kaufen bei BerryBase
Teensy 4.1 is available from Sweden Teensy 4.1
Hope that is a helps. 89 pcs in stock.
I wonder why there so different prices within the EU (EUR 31 vs 53 )
