I tried to connect my new canbus shield v2 with arduino uno to MF 7724. Machine is not steer ready. I’am trying if can get WAS signal through CANBUS. I connected CanH to yellow and CanL to green cable(in X230).
Can you tell me what INO files should I use? I tried with INOs from MCP_CAN_lib-1.5.1
CAN_loopback
CAN_receive
Standard_MaskFilter
It is possible that wrong INO file is not the only problem. My firs time doing this…
Follow my thread here for info on which bus it is. If it’s not steer ready tho (and thus you don’t have the engage button on the pillar), you won’t get far steering it I don’t think, but reading the WAS might be do-able: Steering a '22 MF 6718S over CANBUS
Not sure what speed you’re connected to the Arduino for the serial monitor at, but it should 115200
Hey! I have steering ready mf 8680 '12 and i’d like to get it steering from can bus. So i ordered a arduino uno and shield but how am i going to get them working , maybe someone can give easy step by step instructions ? I do have a working solution by rotating steering wheel but interested if it can be done by this.
I have read this forum and i though that i can change this wheel turning system to work threw can bus with arduino uno + can bus shield but am i wrong. I have the imu and antenna receiver box seperately.
You can use the UNO setup but it has not been updated to the latest v5.7.2 but should still work.
You must disconnect your current steering board and then connect the Uno via USB to AgIO instead of your current steering PCB.
The Valtra program is the one to use.
In AgOpen the tractor arrow in bottom right corner should be red and if you turn the Factory steering switch on the arrow should turn when you manually turn the wheels.
Maybe Project 3 (post 56 here) might be also what you need? It’s pretty old but maybe still relevant
I dont know why its 30 deg and tried to change different settings and it moved to 8 deg. But turning wheel didnt affect. I try tomorrow get those pot and switch to see what happens then. So i put the pot and switch and i should be able to turn the wheels with only one uno+shield. Theres no picture anymore on projekt 3 how to put the wires.
Hey! I can get the arrow to red and yellow by pressing the steering switch in the tractor, and if its yellow in turns to red when i touch steering wheel. Steering angle is 6.7 deg
Yes i got it doing something. It turns the wheels to the right but nothing more, arrow is to green, so we have to try calibrate the tractor’s was, i think theres the fault now.
@CommonRail, Just a question to your teensy board / modified panda board, how I the teensy usb connection is made, is there a SMD Header between teensy and the pcb which contains the belonging usb plug?
