Hello, everyone. I’ve spent hours an hours reading this forum, and there’s indeed a lot of usefull information, though it should be clearer, but in this case, its really nooot. More and more questions and doubts are rising, making me wonder if I’m on the right way. My goal is to modify the FENDT 926 vario TMS - year 2006, to stay on the line, perform a U-turn, and change speed during a U-turn because its possible to set 2 diferent speed options on autopilot. I also want to control the implement at the end of feald (raise/lower)… and I would like to conect all of this using a UDP on PoE switch. The FENDT 926 is an old tractor, and as far as I’ve found out, its not steering ready. I would like to use the motor for steering wheel, which may not be as convenient as a solenoid valve, but everything is about the price…
Currently, I have ordered the motherboard triple CAN V2.0 by @CommonRail (big thanks for sharing your knowledge), but I don’t fully understand if the choice is correct, if I can use it for UDP, and if the power supply via a PoE router will work… Since the tractor is not steer-ready, and steering via the CAN line is not possible, i realise that additional steering control unit is required also… maybe im wrong and its realy have some hydraulic valve already preinstalled for stearing. and if i dont have steering ready, maybe i dont actualy need pcb with 3 CAN…
i would realy apreciate your help and advices to go the right direction. Maybe I dream to much actualy…
Also few assambled CAN V2.0 boards will be available soon if someone interested.
All in one PCB was my first choice, but while reading more and more, decided to go for 3 CAN because of stear on CAN and implement control… but as its not stear ready it was wrong choice, and pcb was allready ordered… but i will go for AIO Micro pcb now… only need to understand witch one is the latest.
thanks for your advice
Hello @CommonRail,
I am thinking of putting a Keya Motor to pilot the steering via CanBus (both for Challenger and TG).
For the Challenger, as a tracked tractor with no WAS and return to 0 steering, if the Teensy code for PCB 4.1 already covers it (with or without Keya), can you clarify how will the Teensy know that it does not have to rely on a WAS to correct the steering ? (I did not find any clear indication in all other Differential Steering discussions),
And if this works for the Challenger, I guess we are not far for enabling this for any tractor (back to “other no WAS” discussions, but here, via CanBus). Does this sound feasible ?
In the aio canbus ion the engage message is setup for Valtra. On MF the message is the same other than it comes from a different ID. The MF sends from ID 00 and Valtra 32. If you change the ID in the can all brands file from 32 to 00 it will work. You have to change it in the filters for brand1 line28 and further down where it reads the message line 361.
hello, I got a tony canboard, I put it together, the subject: fendt 930 vario 2006, I connected can3-Vbus correctly, I also set the brand and panda mode in arduino, the tractor accepted the sent messages, because if I pulled out the wire steering error was written on the dashboard. but no data came from the WAS and it did not control the tractor. the steering button on the tractor just flashed and nothing happened. help me, what could be the problem? then I tried with arduino uno and seeedstudio canshield v2, but I didn’t get anything either, when I connected the wires, only the rx led lit up and the tx didn’t, no can messages came.
Thanks in advance !
