I am building my first AgOpenGPS system. I have a problem with NTRIP RTK. I am using a simpleRTK2B V1 board and a free French ntrip caster (caster.centipede.fr) but I can’t get it working in agopengps. This setup is working great with the Ublox U-center tool (I can get RTK fix).
J’ai passé le paramètre GGA à 5, sans succès. Avec ou sans username/password c’est pareil.
Pour ma connexion, j’ai testé depuis mon lien fibre en wifi et ethernet, en partage de connexion 4G depuis mon mobile, le résultat est toujours le même.
Ma machine est en windows 10.
Try disabling IPV6 on your PC (see instructions in link below). I cant remember if this was the error message I was seeing, but I found that AOG cannot ingest NTRIP over an IPV6 connection.
Thanks a lot for all those ideas
I tried about all : changing the default browser, restarting the PC, disabling the firewall, disabling ipv6. But still same problem.
I also re installed AgOpenGPS, tried an older version, no better results.
I have compared the network frames with WireShark between U-center and AgOpenGPS. It appears that U-center is connecting to the server and exchanging a lot of data (about 10 frames per seconds). On the other hand, AgOpenGPS is connecting well, exchange one or two frames and then nothing during 5 minutes, then connect again, a few frames exchange and nothing more…
So it is connecting well to the server but don’t seem to be able to talk to it.
One thought, is there a distance limit for the Ntrip Mount ? The one I am connecting to, is 20km far from me. Can it be a problem ?
Well, I remplaced the centipede caster by rtk2go, with the same mount, and it is now working like a charm .
Very stange problem, but it is working now, so I can go further in the project.
Thanks to all for your help.
I also had a connection problem this morning after restarting my computer. I found that by clicking on confirm IP in NTRIP configuration the IP address 147.100.179.214 was transformed into fe80 :: 250: 56ff: fea4: 8801% 3 .
The problem disappears when I open the page https://caster.centipede.fr/ in chrome.
It’s strange but if it can be useful to others …
