Sorry für beeing so narrow minded but can we continue these kind of questions in the Dual GPS topic. This one should be about the dual GPS PCB. Otherwise it’s difficult to follow the original topic.
Is the radio for receiving the rtcm? Does it communicate over serial lines? Than the H1 with p32 and p33 should be enough. In the esp we can forward the data to the input of the f9p.
At the moment both tx/Rx 2 ports of the f9p are connected to each other.
what do you mean exactly?
Edit: Ok, saw that one whole is a little bit different to the UNO design. So adapted it.
The Preview of Easyeda does not actualize, but in the Project itself it is updated.
looks good i guess. if doesnt work we can just hook up the radios like jhmach has been. from the xbee pins
I have never ordered off of here before, always had a gerber. How do I order from this link? Thanks
go to link. then Click open in editor. Go to fabrication tab PCB Fabrication File (Gerber.
Actually you can do everything from the file tab in easy EDA
- Export BOM
- Generate PCB Fabrication File(Gerber)
- Export Pick and Place File
Oh wow. You are fast
I hope someone looked at it closer to spot any of my faults
Please be sure, that you ordered the one with the new labels “ardusimple f9p” instead of Arduino Uno
Ya, we’re in a hurry. It’s near time to plant.
it’s v1.3 with f9p. I have to admit, you scared me a little.
Thanks for the quick work, Benjamin. Will report as soon as we test.
Perfect. Looking forward to it
Benjamin, could you look at my post in Dual GPS setups
Am having trouble loading ino.
Got one together.
I find that I have 3 different height of headers in my parts pile, but dont see in the description how to order the correct height. The f9p’s need to be a little taller to miss the ethernet connector with the pvt antenna connection.
Great, hope everything works out as it should.
Extra long header connector?
No, I was looking for the female ones to solder on the pcb. I saw some long round ones in 40 pin strips. Didn’t find any long ones in the us though, and am running out of time
Hmm maybe some creative stacking would help. Cant find much variation on insulation height. for single row .1 pitch headers. Maybe board arrangment will need to be tweaked a bit
do you have female headers under the w5500? could direct solder it to the board maybe
Ya, thinking about soldering the next one direct. I have it all assembled with the cables on, and there us enough room, but would like a little more. I’ll go get some pictures
Benjamin, I have it together, but no power to esp. I only have 12v and ground coming in. What’s the other 2 terminals for ?
I had to remove the w5500 to plug USB in. Might be able to get to it with a 90, but I dont have one. F9p’s have power. Haven’t got GPS coming back yet through USB. I didn’t need to jumper the ioref, right? It looked like you did that on the board. I did forget to change to true in eprom when I loaded. Will try to reload in a bit. I’d take any advice you have.
any luck yet. or is their an unforseen issue with the dual board.
I took it back to the bench. Going to look at the pcb schematic tonight and try to figure out the power issue, and why I’m not getting anything from the f9p’s through the esp. Hoping Benjamin can help
Edit
Looked at the schematic, and it has power to esp32. From what I can tell. Everything looks correct. I’m starting to wonder about my nodeMCU’s. Finally got the ino loaded in them, but they aren’t powering. Going to put 5v to the bottom left pin from a converter plus ground and see.
Edit
Think I found it. Will try tomorrow. Rookie mistake
