I have the autosteer PCB functioning and am working with the GPS.
I have a U-blox F9P connected via USB to my PC. AOG says my GPS port is connected. I have my Baud rate set at 38400. The NEMA string says “Initial Setting”. Data Source is Fix From GGA (NMEA Hz is set at 2). Do I have to set up the receiver in another program. The receiver worked with AOG version 3. Any guidance would be helpful.
I can upload the Firmware file. However when I try to transfer the Config file to GNSS I get an error message that “there were errors or conflicts”. Is this normal?
I also do not get any indication that the firmware update ran when I hit go. I have learned that when the firmware is successfully updated it should run messages in the command line and end with “Success”.
You’re in the firmware upload, that’s not where you’re uploading Config files. There’s a difference between firmware and Config files. I’m not with my pc now but l’m sure you can find information here on the forum, for instance in this thread
Make sure you use the corresponding Config file for the right firmware, now the newest firmware is 1.13.
I am back at this project. Thanks for the tip for attaching to the GPS port.
I now have the receiver connected to ucenter and it is reading my location. However, I still cannot get the firmware update to load. I have been searching on the internet and others are having firmware issues as well. Can someone check my screenshot and give me some idea what might be my problem. See screenshot.
The F9p works well without rtk, I did this autumn seeding in “single” mode.
But Aortner is also correct, because when you come back to the field an hour later, the A B line has moved some centimeters to the side, so you have to center the line again.
U-turn also works well.
But my winter project is to set up a base.
