Good morning.
I have just received my faceplate, great achievement.
what antenna extension did you use?
THANKS
Sorry but I donāt know! I made the faceplate design but I donāt actually have a standard F9P AIO, the pictures are of someone elseās setup.
Is this what you mean
jlcpcb wonder if the orientation of the FH1 is correct?
Yes or no?
Itās a fuse, both directions correct.
ok
THANKS
Hey. I have the same issue, but i canāt sort out what is the problem. Teensy firmware uploaded multiple times, gps firmware updated and configured multiple times, but always the same result. Every pin reheated/soldered, same result. GPS working without the board with microUSB. I canāt figure out the problem.
Is the teensy orange light flashing?
Have you changed the upd addresses to match the teensy
If the orange light isnt flashing either the teensy isnt connected or it hasnāt got a code on it. Should be flashing an orange light when its running a sketch.
Have you followed the steps here to flash it.
Also @andyinv has produced a new/easier way to flash the teensy but i cant find the link now
Here it is
Same result. Teensy orange led not blinking.
You donāt get the serial signal from the F9P !!
Log says, ADC Connection OK, BNO8x OK
Swapping GPS ports means, Teensy is trying to connect f9p, but there is no answer.
Check out connection between Teensy and f9p slot, power supply f9p slot
configuration F9p,
Did you store f9p config on the flash??
When you take the teensy away from the pcb and connect your cable to it does it blink orange at all then?
Put up a picture of your board
You need do connect an antenna !!
Take your cable off and power it via the ampseal.
The cytron isnt lite up either.
You wont get a gps signal with no antenna attached.
If the teensy was flashing orange before you started it was running the blank sketch. If its not running any sketch no lights will be on
Nothing changed with ampseal, the cytron will be 24v, so thats why isnāt lite up.
If i pressed the white button on the Teensy the red led started to blink.
Im not sure what the red light means.
Sounds to me you havnt got a valid sketch uploaded to the teensy.
Try a reset on the teensy and start again.
When you connect you ethernet/udp cable does the front of the connector light up green and flash orange
Try a different usb cable
Are you definitely trying to upload the correct file
