Wheel Angle Sensor Installation Examples - Lots of Pictures
Yes there is a OEM sensor in the kingpin, it was a backup plan.
The linear sensor took minutes to fit and works really well, if it fails can be replaced in minutes for £30.
Do you have a link to that linear sensor?
Linear Sensor for sale | eBay
measure your ram stroke,min to max then order the next size up :+1:
a quick solution in case of trouble to recatch autosteer and find better time to do better sensor
Here is my solution for sensot on a New Holland T7.210 Terraglide™ axle.
5$ Princess Auto sensors
Here with 3D printed parts to be monted on the kingpin.
Some arm expenders
Here is my setup, a piece of hydraulic hose will flex but not twist, 8 mm bolt fit inside
Here are pictures of my KYOCERA/AVX 9197000010 installations. The ball joints have M8 thread.
Fendt 820 COMIII
Fendt 415
Fendt 514C
Do you get and false readings from the sensor when the axle moves up and down?
Hi Pat. What plugs are you using for the Princess Auto sensors? I have some sensors but not sure what plug fits them. Thanks
Here check this thread:
Valtra T0
