Thank’s a lor Larsverst for your explanations on the system.
I have several questions to try to install AgopenGPS on my NH T7.210.
I tried to achive the simplest diagram as I can. Would it works ? (I have doubts because I take back the base from ludo’s diagram.
-I don’t really understand how works the dump valve on ludo’s diagram(and it wouldn’t feet like on the electric diagram that Larsvest give us.
I also don’t really understand how Larsvest connects the steer button on the Electrical systems diagram.
I also don’t really understand what means the wire yellow-green on ludo’s diagram connected to the pressure sensor. (And how can it works if I just don’t use the SRD-05VDC-SL-C relay ? the dump valve won’t stops to work?).
At the left part side, I have only useless wires wich go out. That means that I have the pins 1,2,3,11,12,13,21 and 31 from X-716. (and only the 1 (wich should be GND) could be usefull for the mounting but that’s not linked to the ground. So I think that I’ll connect the PCB to a 12V plug in cab. On the X-720, I haven’t got the 3187 wire (but the 3 useless wires for diag).
So I should directly use the wires from the right part behind the trim (X-710,X-623 and X-711). And on the Service Manual diagram, that would mean that the elelectricity from Cytron (if I use it) wouldn’t pass anymore by a relay but directly by the valve (or I didn’t well understood diagram ?) (And so I should shorts wires to connect them to the relay).
Larsvest on the K-050 1001AC you write that wire has power only when starting /shorting engine ? (does it mean that I would need to feed it in 12 V ?)
Which model of transistor do you use for the transistor behind the potentiometer ?
Thanks a lot for the answers
