Hi guys i have a massey 5s autosteer ready and quick steer as well. i have at the monent agopen runing with the eletric moter runs good but was wondering if anyone has done a 5s to use the joystick and the was and the tractor hydralick pump ?
Anyone has canbus running on NH T7 2023/2024??
Hello everyone,
everything works fine, even the angege button recently. however, i have a problem with the connection to the bus. when i steer completely to the right, itâs ok, but when i steer completely to the left, i lose the connection to the bus and the indicator displays -50.0°. i have to turn the tractor off and on again to get it back. does anyone have a problem like this?
Hi,
Has anyone done canbus steering on a 555D Challenger auto steer ready? if you have please reach out to me, thanks
Does anyone have an images / diagram of the pins needed to connect to a Massey Ferguson 7S?
Planning on using the AIO v2.5 Dual to control it.
You need pin 7 can high and 8 can low for steering.
And 3 can high and 4 can low for using joystick button to engage.
All can be found on the odb extender connector under the cab right side of chair.
Do we have anybody that is using agopengps CAN mode with Kubota V-Bus on M7-2nd generation?
I have Kubota M7152 autosteer ready, which is connected with Trimble on CAN.
Is that possible to run it on Agopengps?
If the trimble is connected via canbus I think it would be possible. From reading some other gps brands fitting instructions it looks like Kubota uses a danfoss pved-cls like other brands. If you could get a can log of the steering can with the trimble working we can see what messages are used and advise from there.
would try to catch the logs from trimble
Hi
. I am reading this topic from beginning. Now i am at 500. But a lot of links and films are not available anymore. Is there stil a possibility to get them. Nice topic. I want to make a Nh t7 with agopen over canbusâŚ
Have a look here, same tractor pretty much. All you need is a PCB with 1 CANBUS port.
I had the exact same problem on a steyr terrus 6300 which is basically a t7.300. Thereâs a 30cm long cable on the right side of the front axle connecting the WAS with the wiring harness. That one could be either broken or has some other defect. In my case the resistance of that piece of cable was a little bit off and i always got a steering failure message on the pillar display. The mechanic that told me that said itâs a very common problem.
Thank you everyone for the excellent work here. I was able to get my 2011 Fendt 828 steering easily. However, I have a 2009 Fendt 933 (COM3, steering ready, autoguide) that doesnât seem to work. The previous owner was using it with a Trimble system. When I push the button to enable autosteer, the led on the enable button flashes, but doesnât go solid as I would expect.
Hi, Thanks i wil try thatâŚ
Struggling to get any GPS using the CANBUS for AIO sketch from the configomatic.
Is this sketch suitable for dual? Which baud would you select in the service menu?
Anyone sucessfully used V2.5 AIO using dual over Canbus?
Would there be a better sketch available?
Canbus code is for single I think, but also go into service tool and select option P for 460800
I see, I read a post in Steering a â22 MF 6718S over CANBUS thread which you edited to say dual was supported?
I have taken one F9P off of my AIO v2.5 board, added BNO, changed F9P config to single and uploaded the CANBUS for AIO sketch onto teensy.
Ethernet light is green, GPS light is flashing red.
Massey selected in service tool and âPâ
Any idea what would cause this?
Whatâs it saying in serial output?
I donât know 211, but there is usually a pretty good wiring diagram in the instruction manual, where you can see which plug k-bus is in, and isnât there anything about the Fendt one having to be unlocked for other autosteering to work with AOG
