Neighbour has a Deutz Fahr 7250 warrior tractor.
Built-in iMonitor that’s basically a Topcon monitor.
As far as I can tell the ISOBUS parts are unlocked, but no RTK or whatsoever.
Tried to sniff the CAN to see if any messages resemble any other brand but I’m either not on the right CAN bus or it’s indeed totally different. (Maybe the steering is not even via CAN?))
Some Valtra progress for a while. Did some digging for the headland controls both for older Versu T4 and the new SmartTouch T4 (T5 probably works the same).
I’ll try and add those to the code this week after some testing.
Yeah the smarttouch is tougher to crack, you probably need the unlock. Pre-smarttouch uses PVED-CLS but we tried to control valve directly on fast steer smart touch but no luck. Valve is OSPE but actuator is not PVED-CLS, has dual 4-pin Deutsch. My guess is some proprietary version of PVED-CL. Don’t have manuals for smarttouch, only older T4 Versu/Direct.
Gave this Deutz 7250 TTV another chance this afternoon.
While fiddling with the CAN cables I managed to get a PVED ALARM error out
SPN: 520192 FMI: 13
So I guess there’s indeed a PVED there.
I was able to read the wheel angle using Brand = 1 in Tonys CAN code.
The PGN for that is: 0x0CAC1C13
However the factory engage buttons don’t seem to be appear on any of the CAN buses.
I did sniff the CAN buses for anyone interested DeutzFahr_bigConnector_CANSniff.zip (177.4 KB)
Maybe the factory Agrosky iTerminal (running Topcon) is the curlprit? (it has no GPS installed )
I’m steering a 6185 TTV over canbus with an AIO 4.1 board.
The armrest buttons aren’t activated without the factory fitted receiver.
You must have easysteer engaged for auto to work.
If you go into the H Menu, you need to go to U1 → H3 → Steering controller (same icon as gps switch).
When you select the steering controller, "ch_ _ "will appear in the lower display, scroll across to “ch2” and wait a few seconds, it will then change to say “NO.” Scroll across once more and it will change to “YES.” Then hold the minute button (the one you’re scrolling with) for a few seconds and the dash will beep to save the value.
do i need to do something in the intelliveiw terminal?
the joystick activation button - does not say a bip when i press the button.
older non steerReady new holland, they all say bip in that autosteering button.
seams like the valve and joystick is “offline” even with ch1 and ch2 (yes)
Could also put a bodge wire on the back of the PCB from the pin that P0 plugs into to the pin that Vin plugs into (connect P0 to 3.3v). That way even if you plug in a new BNO it will go into RVC without needing any modifications to it.
